Solved
Turn wireless internet into an ethernet connection using laptop
i was wondering if there was any way i could have the wireless connection go in to my laptpop then have the laptop convert it to an ethernet connection that i could then run to my ps3.
2 answers Last reply Best Answer
More about turn wireless internet ethernet connection laptop
  1. Best answer
    Internet connection sharing (ICS) microsoft site has a pretty good instruction how to set it up.
    Will it work..yes but ICS tends to have random strange issues so it is not the optimum way to play games. I would spend the $50 and buy a wireless gaming bridge...some routers can also be made into bridge if you have a old one around.
  2. Best answer selected by whatgrenade.
Configuration Laptops Connection Ethernet Card Wireless Internet Wireless Networking
