hi there, i was just wondering if anybody could help me out with this question i have been asking around? Can i connect my PC to my TV and use it as a monitor? i have a geforce 4 4200 and it has a dvi out on it and i recently purchased a sony kv 32hv600 tv and it has a dvi in. now this is sonys official answer to my question.
"Joel Stewart,
Thank you for contacting SONY Online Support.
The SONY KV-32HV600 Television offers the Digital Visual Interface
(DVI) feature which can accommodate a copy-protected digital connection
(HDCP*) to other devices (such as digital set-top boxes) that have
compatible interfaces. The DVI HDTV input terminal is compliant with the
EIA-861 standard and is not intended for use with personal computers.
*High-bandwidth Digital Content Protection.
SONY TV'S are not designed to be used as PC monitors. A TV'S
resolution is set between 800*600 to 640*480. Standard video output
aspect ratio of a TV is 4:3. 16:9 is the industry standard aspect ratio
for digital video output.
When video is output from a PC, or ANY digital source, to a
standard, non-digital TV, viewed at a resolution of 800x600, there will
be black bands at the top and bottom of the display. When viewed at a
resolution of 640x480 the TV screen will be too small to allow the
entire display to be viewed.
Since the hardware and software in the PC systems is designed
primarily for Digital video input and output, the only way to have
completely viewable video output to a standard TV at 640x480 resolution
would be to replace the digital video card in the PC system with an
analog video output card or to convert the digital video output signal
to analog.
This would correct any Bands, however this would not solve any
resolution issues. A card that is designed for TV to a PC hook-up for
laptops and computer aided presentations would be the only solution.
Sony does not manufacture such a card. Please visit your local computer
store or contact the manufacture of your PC for product information.
Thank you for the opportunity to be of assistance"
sorry i know that is kind of long but can anybody give me any help with my delima. thanks for the help.
"Joel Stewart,
to analog.
