Hi all:
I bought the ASUS RT-AC66R router last week - nice router. However, I am having one issue I'm having difficulty resolving. Hopefully, someone here may have some ideas.
I bought the router when my previous Linksys WRT310N router died. The router handles multiple connections - mostly wired through hubs - throughout the house. There are a few wireless connections also - smartphone, notebook computers, and a Samsung CLX-3175FW printer. When I setup my home wifi previously with the Linksys using WPA2-PSK security, everything worked and connected well. When I bought the RT-AC66R router last week, I set it up with the same credentials - WPA2 Personal security (AES), with the same SSID and same password as before. Everything connects as before - except the Samsung printer. I have determined that the problem lies with the security key. If I enable the router's guest network with no security, it connects right away. If I remove the WPA2 security from the main personal home network, it connects right away. However, if I enable the network with WPA2/AES security, the printer will not connect. I have re-entered the SSID and WPA2/AES password in the printer, but it still will not connect.
Does anyone have any ideas why my printer will not connect through the secured network when all my
other devices have no problem connecting (and previously connected fine to my Linksys with the same credentials)? Thanks for any ideas.
