Tom's Hardware > Forum > Mobility Brands > Motorola > V551 - strange battery charging behavior
Forum Mobility Brands : Motorola - V551 - strange battery charging behavior
Archived from groups: alt.cellular.motorola (More info?)
While charging, it will be showing one bar, then suddenly beep and show a
full charge. Then, a couple of minutes later (still plugged in), it will
show one bar again and be charging away. It has done this off and on all
day as I sit here at work.
I got my V551 yesterday, and it showed a full charge. Since it also came
pre-configured, I assumed they had also did the first 24-hour charge process
and I just started using it, making a few calls during the evening. Then,
this morning, it was beeping that the battery was low. So, I checked out
this forum and elsewhere and heard about the initially short battery life
and the suggestion to give it a full charge. That is when the strange
behavior started.
Sponsored Links
On 6/28/2005 1:35 PM, VBM wrote the following:
> behavior started.
phones don't come with batteries fully charged. also, check your s/w
version (*#9999#) and make sure you've got firmware version 18.16R or
higher. Version 17.0 has known issues causing the battery to drain
earlier. in that case, exchange it at your phone store. i've gomy 551 a
week ago, and it already had the more recent firmware version.
Reply to Anonymous
Thanks, I didn't know how to check that. Luckily, I do have 18.16R, so I am
hoping it is just the connection issue mentioned by another poster.
"nuucp" <nuucp@nowhere.net> wrote in message
news:y5jwe.20$st2.47@news.oracle.com...
a
will
all
came
process
Then,
life
> > behavior started.
Reply to Anonymous
There are 1223 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
