Hello,
I have two PC's 500 meter apart from each other. I want to connect them using LAN but as the distance is more than 100 meter I can't use cat 5 cable to connect both PC's. I want to connect them over LAN using wireless hardware so which wireless hardware I need to purchase. The OS for both are Windows XP professional. Knowing that I will use only remote desktop feature and Internet not available at the location of the two PC's .
Thanks.
Thanks.
