My setup:
Win98
Athlon XP2000+
Corsair XMS2700
Gigabyte GA7-VRX
Here is the situation. I had 256MB of Corsair XMS2700 in my computer. All the memory settings were set to their fastest and I've never had a problem for 8 months now. I decided to add another 256 XMS module. The first one I got caused random reboots shortly after I turned the computer on. I relaxed the memory settings to the lowest speeds and still had problems. The replacement module seems to work fine, as long as I have the memory settings set to their lowest.
One thing I noticed with both modules, when I would set the memory settings to their fastest (the same settings I had on my old module) the computer would boot into windows and I would immediately get a registry error and would have to restart. Once I relaxed the settings, that quit happening.
I've tried all the different configurations for the settings, I've tried all the combinations of slots with and without my old stick of memory and nothing seems to fix the problem.
Shouldn’t I be able to turn the settings up on the memory as long as I don’t overclock?
And also, why would it give me registry errors when I turn the settings of the memory up?
Thanks in advance!
Win98
Athlon XP2000+
Corsair XMS2700
Gigabyte GA7-VRX
Thanks in advance!
