i'm working on the idea of putting my iso booth on a rolling caster
platform, in case i need to pull it out to get to the hvac, wall
outlets.
right now I have 5 rolling casters, forming an X-pattern (4 on the
corners, one in the center). the platform is 5-ply 23/32" plywood.
the size is 48x66.5".
i stepped on it and it's pretty "creaky" and flexy. i'm hoping when I
put the actual iso booth above it, the creaks will go away, because the
2x4's of the iso-booth sub-flooring will be resting on 20 Auralex
U-boats.
i could ditch the rolling caster thing...any opinions?
I could screw in some metal handles to the bottom of the iso booth and
just "muscle" it when i need to get behind the booth.
But I thought the locking casters would be cool, and would also help in
transmission loss... since the 5 casters only touch in small points on
the floor, less shock would get transmitted into the booth from a stomp
or footfall in another part of the building.
so basically, to caster or not to caster, that is the question...
A layer of something cushy between the iso booth and the moving
platform probably wouldn't hurt, but it'd probably also be redundant.
Better safe than sorry? *shrug*
Most important question though, is if the casters are rated for the
weight.
Cheers -
jtougas
listen- there's a hell of a good universe next door
let's go
Something else I should have asked: What kind of framing are you using
to support the plywood?
jtougas
let's go
the rollaround plywood platform has no framing. the underside of the
iso-booth is the 2x4's floated on auralex u-boats.
as i looked at it and played around with it, i came to the conclusion
that i should have many small casters rather than 5 big ones. so it
looks like i'm going to have about 20 casters on the bottom.
<genericaudioperson@hotmail.com> wrote in message
news:1104610219.240144.29320@c13g2000cwb.googlegroups.com...
How about not using casters at all and use some furniture glides instead?
Since it sounds like you'll only need to move the booth every once in a
great while, the glides would make your booth less tall and tipsy and the
glides are fairly cheap and can be easy to attach. ( a lot of them nail on
which is easiest but if you think you'll need to level out the booth get the
kind with bolts. ) Get the largest ones you can find that will work best on
the floor of you studio ( i.e. use the steel capped ones for carpet and
maybe plastic capped ones for wood etc. ) Here's a couple sites to give you
an idea but most hardware stores carry these :
Should be fine.
jtougas
let's go
<< But I thought the locking casters would be cool, and would also help in
so basically, to caster or not to caster, that is the question... >>
Well, it may help you or it may hurt you, but you will also have a resonant
chamber under the platform when raised on the casters. I think it will be
pretty boomy with that air space under there.
