Memory Problem
Well I finally got my new computer working, but the problem is that the BIOS recognizes that there are two sticks of 512MB OCZ PC-3500 EL in Sockets 2 and 3 (Dual Channel DDR) of my A7N8X Deluxe mobo, but under windows properties it only says that i have 512MB instead of 1 gig. Is this normal, I have never worked with Dual DDR before but I know it makes it look like 1 stick but should it not be 1024MB instead of 512MB? So I have to set anything in Windows? Did I get mislabled RAM? Any help appreciated, thank you.
1 answer Last reply
More about memory problem
  1. Try pulling a stick and see how much it reports. (Hint: turn the power off first).
    <font color=blue>You're posting in a forum with class. It may be third class, but it's still class!</font color=blue>
Memory
