Tom's Hardware > Forum > Mobility Brands > Motorola > mobile phone tools and usb problem - help !
Archived from groups: alt.cellular.motorola (More info?)
I just downloaded mft from motorola's site. I installed the first time and
before I upgraded, my phone was discovered (V3) after the program's upgrade
then my mass usb storage driver keeps giving me the yellow exclaimation
mark.
Now my phone can't be discovered ...
Un-installed and reinstalled ( with phone disconnected ) didn't run any
updates, but when I plug in the usb cable, the driver first loads, then a
bit later it goes to yellow - something like it was trying to start the
driver.
Look at Motorola's site, as well as BVRP software site, as well as googled,
but don't see anything. Have any others experienced this problem ?
Thanks,
Devon
Sponsored Links
> mark.
> driver.
> Thanks,
> Devon
Find the com port your USB modem is set for in the control panel.
Then set that com port in MPT.
I did that.
Had to do it again when I got a Blue tooth dongle.
And with P2Ktools
Reply to RobertM
On Wed, 13 Jul 2005 01:33:09 GMT, "devon"
>mark.
>driver.
>Thanks,
>Devon
you must install the motorola modem driver. goggle a bit, you will
find it.
Reply to Anonymous
- 0 +
"Hagen_von_Troje" <vinny602003@yahoo.com> wrote in message
news:c2d9d1hr64v4i9vt56l4ihdph7lodu34d5@4ax.com...
>>upgrade
>>mark.
>>driver.
>>googled,
>>Thanks,
>>Devon
> find it.
Thanks that was it - found the driver here:
http://www.mobiledit.com/download/ [...] _modem.zip
Reply to devon
There are 696 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
