Tom's Hardware > Forum > Audio > Pro Audio > Sound Forge Issue with XP
Forum Audio : Pro Audio - Sound Forge Issue with XP
Archived from groups: rec.audio.pro (More info?)
I am using Sound Forge 7.0b.
Whenever I use the spacebar to play back regions quickly SoundForge 7.0 b
is crashing and causing my Laptop to immediately shutdown.
This has also happened when using midi triggers for markers. I have
triggering set to ch. 16 note on - play, note off - stop.
Using Windows XP Pro w Service Pack 2
HP zd7000 Pentium 4 at 3 GHz w 768 Mb RAM
Plenty of Hard Drive Space
M-Audio FireWire 410 Interface
-Gregg
Sponsored Links
"Gregg" <maze@nospam.com> wrote in message
news:kXxCd.78311$Ix2.8483@okepread02...
As there are zillions of XP SP2 installs of SF7 that work just fine (I have
3), I would guess that your install is broken. Try uninstall/reinstall .
If this doesn't fix, suspect something broken in Winders - try Nortin
WinDoctor or similar. Or most likely given the total crash it could be your
soundcard device driver.
Have you tried Sony tech support ?
geoff ( PCDAW-subscribe@yahoogroups.com if you like)
Reply to Anonymous
There are 640 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
