Tom's Hardware > Forum > Audio > Pro Audio > FA: Neve EQ & Modules, Studer Parts, Cables, Mike Accessor..
Forum Audio : Pro Audio - FA: Neve EQ & Modules, Studer Parts, Cables, Mike Accessor..
Archived from groups: rec.audio.pro (More info?)
Neve Modules, Studer Parts, Cables, Mike Accessories, Scuba Gear, Much
More
Ends Thursday, January 6th
http://search.ebay.com/_W0QQfromZR [...] earchQ3aUS
or search for seller "accordlogic"
Vintage Neve 32069 EQ Mic Preamp
Vintage Neve 32404 Control Module
Vintage Neve 31903 Bus Module
Vintage Neve 32408 Bus Module
Neve 8068 Rear Power Input panel #1804
Neve rear panel interface plate #1805
Henderson 3 piece Wet Suit
Neve compressor linking switches on console panel #1787
Neve 8068 console oscillator type 33513.#1802
UTC A-39 Transformer #1856
Neve 440 Preamp Board
Beyer TR/BV Mic. Input Transformer #1447
Neve 8068 Rear Power Input panel #1801
Neve 438 Preamp Board
Vintage UTC A-21 Transformer #1503
U.S. Divers Navy Mk. II Double Diving Tank Outfit
Neve 1/4" TRS Patch Bay
Vintage Shure 51 Microphone, Rare! #1357
Neve 8068 Bus Master Section Panel #1786
GML Massenburg Automation Moving Fader #1862
Neve Large power supply, 24 volts,#1790
Neve Model 33600 Console Power Supply
Neve Large double power supply, 24 volts #1789
Set of 4 Kinetics KIP pads vibration isolation #1760
Shure Microphone Clip for SM-57, 58, Betas #1835
2 Audio Cables: XLR M & F to Banana #1704
2 Audio Cables: XLR Female to Banana #1703
2 Audio Cables: XLR M & F to Banana #1700
Paper Shredder with wastebasket
Neve Panel: Under console w/XLRs #1508
2 Ultra-Mini folding microphone stands #1630
Heyco 5P-1 Power Cord Strain Reliefs #1773a
¼" 15 and 7.5 ips pink noise test tape. #1776
Snake: 2 1/4" TRS to XLR Male, over 30' #1529
Sub Smart Sunshade "popout" tent
Drummer's 14" practice pad / muffler #1428
A/B data transfer switch with 3 db25 female conn.#1793
Roland foot pedal, working. with ¼" phone plug. #1795
2" Tape Deck Pinch Roller #1797
Pella SD Window Lock #1692
Microphone Gooseneck w/quick clip M & F #1698
Potentiometers: Allen-Bradley J 270K Ohm Log. New
E-V Electro-Voice Model 312 Microphone Clip #1834
Magnum Opus Electronics dB Decibal Meter #1847
AKG D-202E Microphone Clip #1839
Jerrold Time Warner Cable box remote #1782
Chinon Splash GX Weatherproof 35mm Camera #1845
Beyer MKV-8 Microphone Clip for M-160 #1844
E-V Shock Mount Microphone Clip #1840
15/16" - 18 threading die #1660
Neve Edge Connector Panel #1497
3 Microphone Quick-ClipAdapter sets #1644
5 Microphone Quick-Clip Males #1647
10 New DC Wall-Wart Power Supplies
10 Omron "ice cube" 24v relays 4PDT
10 IRE Journals (Electronics, WWII technology)
Studer Parts: Brake Solenoid spring rod #1723
Studer Guide roller cap for 2" machine #1665
Studer Parts: Photocell Board #1718
Studer A820 Control Board : Part #1.228.821.13 #1671
Studer Parts: Two 2N5684 Power Transistors #1684
Studer A800 Parts: Brake Bands 1.180.107 #1685
Studer A820 Control Board : Part #820-773-12 #1663
Neve Solo PFL light and switch panel. #1495
6 Em-D-Kay Showcase Locks #1691
Studer Machine Part: Spring loaded control arm #1687
Studer Tape Machine Parts: 3 Pinch Rollers #1686
Studer Parts: Studer Guide Roller Cap #1717
Studer IEC Reel adapter for 2 track Machines #1666
Studer Parts: Set Screws or Threaded Rods #1734
Studer IC Part # 1.081.998.00 #1681
2 Audio Cables: M-M & F-F XLR Adapters #1854
2 Audio Cables: 1/4" Phone to Bant Patchbay plugs #1855
AKG K240M Headphone Replacement Drivers #1816a
2 Audio Cables: XLR to Bantam Patchbay plugs #1857
2 Audio Cables:1/4" Phone & RCA to Bantam plugs #1858
2 Adapter cables RCA to Banana #1489
Snake: 4 Channel XLR to 1/4" Phone #1517
120v to 100v Converter Transformer #1544
2 Audio Cables: 1/4" Phone to TRS Patchbay plugs #1853
Studer Control Board : Part #1.820.770.00 #1677
Studer Parts: A-80 Brake Drum #1725
Studer Parts: Hexagonal Rod Mechanical Part #1728
Studer Parts: 2 Springs #1731
Studer Parts: IEC Spindle Parts for 2 tracks #1733
Studer Parts: disks from reel table ass'y #1736
Studer Parts: Spindle #1720
4 Cables: XLR Female to 1/4" Phone #1485
Brother Executron 65 Electric Typewriter #1864
AKG K240 Headphone parts #1816
2 Space Black Anodized Rack Mount Project Boxes (10)
Pair Dolby Cat. No. 22 Noise Reduction Cards
Sponsored Links
There are 1141 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
