Tom's Hardware > Forum > Mobility Brands > Motorola > V551 Ringer setting want stay where I set it (HELP)
Forum Mobility Brands : Motorola - V551 Ringer setting want stay where I set it (HELP)
Archived from groups: alt.cellular.motorola (More info?)
The button on the side of the 551 is easily hit and changes the ring
option, ususally to silent. Is there anyway to disable this button so
that the ringer option will stay were I set it.
Sam Roe
samroe@hotmail.com
Sponsored Links
Try hitting Menu + * to lock/unlock the keypad (Side buttons are also locked
when you do this). If it doesn't work, then you need to enable it through
seem editing. SEEM 0032_0001 - offset 29 - bit 1: Settings > Security > Lock
Keypad (1 on, 0 off)
http://www.xlr8.us/hofo/
d
<kb7qqq@gmail.com> wrote in message
news:1122409222.972434.109740@o13g2000cwo.googlegroups.com...
> Sam Roe
> samroe@hotmail.com
Reply to Anonymous
- 0 +
> d
>>Sam Roe
>>samroe@hotmail.com
Try ---Settings>security>lock application, then you can select whichever
application, like the ring styles, to lock. Thanks to someone who gave
me this advice sometime ago here, and it worked on my V551!
davidT
Reply to davidt
There are 928 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
