What are the objective of web application + wireless and wired network intranet
what are the objective of web application + wireless and wired network intranet + java
3 answers Last reply
More about what objective application wireless wired network intranet
  1. Web applications are applications that run in a web browser.
    Intranet is an internal web page, usually for companies.
    Java is a programming language.
    If you want to find out the "objective" of those (as in why use a web app instead of a regular .exe installer), there are plenty of books and articles on each subject, just check around the web, this is not the place to re-write articles which is what your question really requires.
  2. Ok, thanks. But can you help me and get project topics related to ( web application + wireless and wired network intranet + java )
    You are asking for info for a large chunk of the planet's internet and application base, do a web search, you will get the same info anyone else on the forums will, and you'll be able to put in more detail about exactly what you are looking for.
LAN Wireless Intranet Java Networking
