Tom's Hardware > Forum > Windows 7 > Help! I changed something in Disk Management.
I don't know what I did. I have one physical hard drive that I partitioned in three partitions when I installed Windows 7 RC (and a 4th "System Reserve, created by Windows). Windows 7 is installed on the first partition, the other two has not been formatted yet. Then today, I went in to Disk Management to change the size of the partitions and to add another one (for other test installations of Windows).
As I played around with sizes, I deleted, created and shrunk the various unused partitions. All of a sudden after I did something, all the partitions now no longer say "Primary Partition". The blue color on top of the partitions also changed to a yellow/brownish color. My guess is that they have been converted to a Simple Volume instead of a Basic Volume, so that a partition could be spread out on both sides of another partition. The disk itself is still a Dynamic Disk. But by right-clicking I can't see anywhere where to convert a Simple Volume to a Basic Volume, if that is even what I should do.
Does anyone know what I did, and how I can get things back to how they were. Did I do any harm?
I'm a bit confused about the terminology, Simple Volume, Basic Volume, Basic Disk, Dynamic Disk, Primary Partition, Extended Partition etc.
Thanks for any help.
Sponsored Links
Hi D
Disk Management is not the best tool for managing partitions. I personally use Paragon (DOS) which basically allows me to do anything I want including deleting and moving files. Unfortunately you have to pay for it but I'll link you to some freeware. Repartition the other space as primary also, however, do not set to active. You should only have one active partition.
http://www.thefreecountry.com/util [...] tors.shtml
Reply to starams5
[quotemsg=3408,2,378142]Hi D
Hi starams5,
I don't think I should need any additional partitioning software. My needs are very modest. I just need to create 4 partitions on the same drive, not resize existing partitions etc.
Do you, or anyone else, know how to change a Simple Volume back to a Primary Partition? In XP, I think you could to do this by right-clicking, but no such option in Win 7?
I now have one partition with my Windows 7 installation, which says it's a Simple Volume on a Dynamic Disk. The rest of the space is unallocated. There's also a 100 MB System reserved partition. How can I change my main C: partition back to a Primary Partition instead of a Simple Volume?
Reply to don69
After searching the web some more, I think I converted my drive from a Basic Disk to a Dynamic Disk, thus the Primary Partition changed to a Simple Volume. As I understand, there's no way to change that back without losing data (the @Convert to Basic Disk command is grayed out).
I would appreciate if someone could explain what implications this will have. The system seems to run normally, but if there is any disadvantages, I'd prefer to reinstall Win 7 now, rather than later when I have more software installed.
Reply to don69
There are 679 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
