Can i use a netgear wireless card to access belkin wireless access point
have netgear pcmcia card need to connect to new belkin wireless access point.
1 answer Last reply
More about netgear wireless card access belkin wireless access point
  1. They should work fine together assuming you have the correct security type and password entered in the laptop, and the wireless radio type of the card is allowed on the Belkin. An example of a problem would be if it was a G wireless card and the AP is set to N only, otherwise you should be good.
Configuration Wireless Wireless Access Netgear Belkin Wireless Networking
