Can we connect to access point using both wired and wireless medium
StevenGibson1994
153
would i need to connect the access point to the router via ethernet cable to achieve a wired connection, as i am wanting to have a wired connection in my bedroom but my router is in my living room on the otherside of the house.
RealBeast
Yes, an access point needs to be connected with a cable or through powerline adapters if that is not possible. But if you get a router that is dd-wrt firmware v24 capable, you can set up a client bridge like THIS if your signal is strong enough at the point where you place the bridge.
StevenGibson1994
153
RealBeast
You could connect the switch to the network with Ethernet and then attach the AP to the switch.
It would be cheaper though to just buy a TP Link wireless router, set it up as an AP, and connect it with an Ethernet cable that would leave three available Ethernet ports (the 4th LAN port would be used for the connection to the main router).
