Antec Power Supply FAN position
Last response: in Components
I bought a Antec 430 True power supply based on reviews and an alluminium case Jupitor Sky. unfortunately the Antec has a Fan on Top, and my case does not have a whole on top to match it.
But when I fixed the power supply there was a aboutt a a 1/4 inch space between the top and the power supply.
I am hoping that this space is enough for the Antec fan on top to suck and keep the system cool. And I am hopping the aluminium case helps. I am hoping not have to drill holes on top of the case.
Will this be a problem. Do I have to drill holes or is it ok as is.
Thansk for responding. I did try fitting the fan such that the big fan faced downwards towards the CPU. But the drilled screw holes on the power supply as well as the case wouldn't fit at all.
Whenn I turned it around the way it is right now, it fit perfectly. So I assumed that the power supply was designed suck in air from the top either through a case with hole on top or through the gap between the ceiling and the P/S.
Sarvi
The big fan is an intake fan not an output fan, the air exhausts out the rear of the power supply, I don't know what kind of case you have, but I've got the same power supply with the big fan exhausting air from over the processor, you may need to order an adapter to be able to turn it over, or break out a drill, and drill the holes you need in the case, thats what I'd do in this situation, or leave it like you've got it, it will still pull air out of the top of the case, just make sure you've got about an inch clearance from the top of the case, so the fan doesn't overheat from lack of air flow.
Details, Details, Its all in the Details, If you need help, Don't leave out the Details.
No. Your case is designed with the power supply upside down. I've seen this before, usually on cheap power supplies. You might be able to modify the case so the power supply is mounted correctly, but with the stock case it's upside down, and yes your case was designed that way, I don't know why.
<font color=blue>There are no stupid questions, only stupid people doling out faulty information based upon rumors, myths, and poor logic!</font color=blue>
The fan should be pointing down to help remove hot air around the CPU and motherboard... otherwise it is almost totally useless.
My dual-PSU PC is so powerfull that the neighbourhood dimms when I turn it on :eek:
Ask the community
