So i am very new to building website and do not know where to start
I want to create a online portfolio, but not just the "standard" one that looks like a blog create by 5year old
I want to have a awesome intro like the Sony website has and also nice interface (like a prezi). I am a fast learner so i can learn adobe Dreamweaver if i need to
also how does it work? do i create the interface and than can i upload it as a template or do i need a certain kind of service to put it on the web or what?
I also want to have a recommendation section where the employer cant see it until I give him a code or something to type in the website and than only the letters that i have given him the code to be unlocked or a contact form where along with info the employer fills out a password/code that i sent them with my hard copy of my resume, which unlocks the recommendations or can post a question
also i don't want the website to be in any search engine, only through the address.
I have a lot of options to choose from in terms of buying the domain. which one would you recommend
http://www.***/
http://webstarts.com/pricing.php
https://www.yola.com/pricing
http://www.ucoz.com/
http://imcreator.com/
wix.com
webs.com
http://www.jimdo.com/index.php
http://www.weebly.com/
I really want the site to be simple and detailed, (so when they hover over the specific section, they get a little box with detailed info)
any help would be fine, i dont need massive storage space or anything like that also one or two email is fine.
http://www.***/
wix.com
webs.com
