Tom's Hardware > Forum > Mobility Networks > Sprint PCS > 5300 vs vga100 need help
Forum Mobility Networks : Sprint PCS - 5300 vs vga100 need help
Archived from groups: alt.cellular.sprintpcs (More info?)
I remember reading here that someone had a fight with lockline because they
were sent a samsung vga1000 in place of a sanyo 5300.
Lockline said the 2 phone were the same and this person proved to them they
were not.
I need help!!!
Lockline did the same thing to me and I HATE SAMSUNG phones!
SO I need that list to thros it in their face and push for a 4500 or
something
Thanks for anyones help!!
Sponsored Links
In article <Xns94CBDA7E1C4D9sirtronicsmonmouthco@167.206.3.2>,
> were not.
> I need help!!!
> something
Compare Sanyo 5300:
http://www.phonescoop.com/phones/phone.php?p=193
with Samsung:
http://www.phonescoop.com/phones/phone.php?p=318
Doesnt the 5300 Camera have Zoom capability that the VGA10000 lacks?
Subject: Re: Sprint Insurance FYI
Newsgroups: alt.cellular.sprintpcs
Date: 2004-03-08 06:49:42 PST
This is the whole thing in a nutshell. They are relying on the fact
that you are desprete, your phone is broke and at this point you will
accept anything they send you . In my situation, my lcd was wacked out
(actually it has been working ok for the last two days, go figure). I
could still use my phone. So when they sent me the replacement phone
that was not even the same brand, I found it not to be comparable or
better. I purchased a sanyo because of specific features and the phone
they sent me does not have these features. They are clueless call
center people who just repeat what they are told to say! Just bitch
until they give you a supervisor and be prepared to go over feature
for feature. They will have no choice to give you a better phone of
the same brand.
Reply to Anonymous
Robert M. wrote:
> Compare Sanyo 5300:
> with Samsung:
No, the VGA 1000 has zoom also. 2x zoom in medium resolution and 4x zoom
in low resolution. No zoom in 640x480 though.
IIRC, the 5300 has an actual flash. I've never seen another camera phone
on Sprint that has a proper flash like that. The VGA 1000 simply has a
white LED that provides some extra light.
The 5300 has call screening. (It's a built-in answering machine. You can
hear the caller leaving a message on your phone's built-in memory.) I
don't think anybody but Sanyo has this.
Reply to Mike
"Mike" <spamtrap@zbuffer.com> wrote in message news:5Nmfc.10821$A_4.521@newsread1.news.pas.earthlink.net...
> sirtron wrote:
> For me, the VGA1000 has been a bad experience. It has poor battery life,
Have not noticed this with mine.
> very slow boot,
Agreed.
> poor stability w/ lots of reboots or freezes, lots of UI
> bugs,
Have not noticed any of the above.
> sometimes refuses to place calls because of a non-existent data
> session,
This has happened to me a few times. I have to remove and replace
the battery when this occurs.
> voice dial tends to reset the phone, handset gets very hot, a
> keypad backlight that is completely random, a call display that loses
> track of who you're calling (Call one phonebook entry, hang up and
> immediately call second phone book entry. Second entry name will appear
> while the phone calls the first entry.)
> and a camera that often turns
> itself on when I open the flip. (This is somewhat repeatable, so no, I'm
> sure I didn't hit the button)
I sometimes push the camera button on the right side inadvertently.
> There is a firmware update that I had applied that stopped some of the
> UI issues, but I had much worse RF performance afterwards. That update
> also makes the external LCD light up whenever the volume control is
> pressed while the flip is closed - previously, the external LCD would
> only light when the volume is pressed for about a second.
I've been wondering if I should get the firmware update done.
Has anyone else experienced worse RF performance afterwards?
John Richards
Reply to Anonymous
>>very slow boot,
> Agreed.
>> bugs,
>>session,
This afternoon, I had this problem. The dialog box couldn't be dismissed
this time. It told me to press OK, but it wouldn't go away. I held the
talk button until the voice dial menu appeared, and I could make a call
again. I don't know if it will work next time, but I was happy.
If you set your keypad backlight to something on the long side, like 30
seconds or flip open, you don't find that your keypad backlight goes out
in about 8 seconds? I first noticed this when I set both my main display
and keypad to 30 seconds. The main display was on much longer.
Yes, tried to make it clear that it was _my_ experience. I should tell
you that I've seen other people at Sprintforums.com complain about the
VGA 1000. Most people seem to have fewer issues than I have. Many have
simply had problems with some sort of beeping noise made by the phone.
I've never had this happen. Most have been happy with the firmware
update, though the change on external LCD backlight behavior and failure
to resolve this beeping issue were not well recieved.
I updated the firmware on the second of this month, and since then, I've
had trouble getting through a fifteen minute call without having it
dropping, even with a good signal on the indicator. Could it be
something else? The person at the counter gave me a hard time, could
they do something malicious?
Right now, my phone is plugged into the charger. An hour ago it played
the removed from charger sound. It's now back to two bars from three,
and nothing I can do will make it charge again...
Nevermind, unplugged the charger from the wall and plugged it back in...
I wonder why unplugging it from the phone didn't work. In fact, it
played the removed from charger sound when I pulled it off the wall.
Maybe my charger is going out now too.
I think I'm off the thread topic now. :)
-mike
Reply to Mike
In article <UImfc.10818$A_4.3043@newsread1.news.pas.earthlink.net>,
Mike <spamtrap@zbuffer.com> wrote:
> Robert M. wrote:
> > Compare Sanyo 5300:
> > with Samsung:
So basically you agree with me. The Sanyo 5300 is a more feature rich
phone to the Samsung VGA1000; and the VGA1000 is not a proper
replacement by Linkline for the Sanyo 5300.
Reply to Anonymous
> Tell them that your phone has to have a real flash, and not some white
> LED.
> -mike
Naw, a REAL FLASH is one where you need to carry a pocketful
of those little glass bulbs with the magnesium filaments! :-)
---JRC---
Reply to Anonymous
"John R. Copeland" <jcopelan@columbus.rr.aol.com> wrote in message
news:kjwfc.1949$nv3.1419@fe1.columbus.rr.com...
> LED.
> -mike
---JRC---
Yea, I was going to mention that with the 5300, unless you are within 3 feet
or so of the subject for the picture, the flash is not all that useful.
Bob
Reply to Anonymous
There are 617 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
