Archived from groups: rec.audio.pro (
More info?)
In article <csg9lt$rmk$1@hercules.btinternet.com> hophed@hotmail.com writes:
> M-Audio USB Audiophile - I'm concerned that it only uses USB1. Is this
> reliable for recording and playing back audio?
They don't let you get into trouble because the card won't exceed the
througput capacity of the USB data path. You can do two tracks in and
two tracks out (like for overdubbing) at 44.1 or 48 kHz, 24 bits
without a hitch, but when you double the sample rate, the throughput
rate isn't fast enough for four "streams" so you can only record
(without monitoring the playback) or you can only play back when
running at 96 kHz. In other words, at 44.1/48 kHz, it's fine for
building up tracks. At 88.1/96 kHz, it's fine as a stereo
recorder/player.
> Behringer BCA 2000 - Uses USB2, but some people have told me that Behringers
> do not sound good and have usability issues.
Some people will tell you that anything made by Behringer does not
sound good. Some things do, some things don't. I would be suspicious
of anything really inexpensive. M-Audio gear for the most part is
priced about where you expect it to fall. Behringer gear, for the most
part, is priced lower than you'd expect for the capability. Something
has to give. Sometimes it matters more than others.
> Can anyone recommend which of these, or any others which would be good?
Not until you figure out what it is that you need to do, what you want
to do, what you can't live without, and what you can live without.
When it comes to simple desktop recording, I think the TASCAM US-122
is as good as it needs to get. It's USB 1.1, it's very well thought
out in terms of signal routing, it has usable mic preamps, a decent
headphone output, outputs to speakers that are easy to mute when
working with microphones and speakers in the same room, and it sounds
OK. But if you can't live without 96 kHz sample rate (and I don't know
why you'd want it at your stage of the game) forget it.
> Also, is there anything else I would need in my simple set up to get some
> basic home recording going?
Lots. Develop a good, friendly relationship with a dealer, even if it
means driving a couple of hours to get there. If you order a bunch of
stuff from the cheapest on-line sources you can find, you'll be months
getting up and running. That's no fun.
I'm really Mike Rivers (mrivers@d-and-d.com)
However, until the spam goes away or Hell freezes over,
lots of IP addresses are blocked from this system. If
you e-mail me and it bounces, use your secret decoder ring
and reach me here: double-m-eleven-double-zero at yahoo
