I am not very good at the topic of wifi and wireless networking so it probably something simple that's wrong. I bought an intel centrino advanced-n 6235 for my PC. There is a slot for miniPCIE cards on my motherboard(Asus Maximus V Gene) and I set it up but it won't connect to the internet.
When I booted it up with the card for the first time it said a few of the drivers didn't install correctly. I downloaded any drivers I could find and done an check on intel.com after which said I have the newest drivers for it installed. If I go to network and sharing center->Change adapter settings it lists the wireless card there. All green bars are full at the symbol for the card but there is a red X next to it and it says not connected. It seems to indicate that everything is installed correctly because I can change the cards settings etc. but it won't get any connection. Any ideas what's wrong?
I have guessed it might be that I need an antenna as I did not fit any yet and also in the Asus Maximus V Gene manual part of the miniPCIE card setup shows antenna fitting as part of setup. Do I just need an antenna or should the card work anyway? Also if I need antennas do I need one or two?
