Archived from groups: alt.cellular.sprintpcs (More info?)
Looks like I'm getting an A680 tonight. Anyone know if my power adaptor,
car charger and extended battery from my A500 will work with this device?
That would so rock if they do!
> Thanks again everyone!
Power adapter and car charger will definitely work. Don't _know_ that
the battery won't work, but it is very likely that it will not.
-mike
"Mike" <spamtrap@zbuffer.com> wrote in message
news:B4Wjc.13393$eZ5.10584@newsread1.news.pas.earthlink.net...
adaptor,
device?
> -mike
"Blargh" <Blargh@nunya.com> wrote in message
news:F8Wjc.16820$Qy.3591@fed1read04...
> adaptor,
> device?
> > -mike
> How about data cable? Forgot about that!...
If it uses the same charging cable, you should be able to use the same USB
cable.
>>-mike
Probably not compatible. The A500 and N400 had a unique connector to
support the camera accessory. Most of the other vision handsets from
Samsung use the A310-style connector.
-mike
Oh, and I'd suggest getting the cable off of eBay. There are supposedly
some charging data cables out there. Some of the new Samsung handsets
have SCI charging connectors that are positioned too close to the data
port to allow both connectors to be attached.
-mike
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
> cable.
> Bob
The charging cable and the USB cable hook to separate ports on the A500,
so it is possible that one is compatible without the other being
compatible. IMHO the USB cable interface to the A500 was rather
problematic ... but I didn't use a USB cable hooked to that phone much
for it to bother me any.
Thomas T. Veldhouse
Key Fingerprint: 2DB9 813F F510 82C2 E1AE 34D0 D69D 1EDC D5EC AED1
Ohh, boy howdy! That was a problematic connector! The camera was a pain,
the data cable was a pain. It was all a big pain when it came to the
A500/N400 data connector. You had to push it in and wiggle it a little
side to side to make sure both latches were in. Even then, a little crud
and it wouldn't work. You take it apart, blow on the connector (like an
Atari game!) and try to hook it up again.
-mike
In article <m92kc.17036$e4.12431@newsread2.news.pas.earthlink.net>,
Did your kids get peanut butter on the connector?
I was friends with a Store owner, and they only had complaints about
Commordore connectors. You needed a pencil eraser to clean the
connectors regularly.
