Yes No
Ads
Tom's Hardware > Forum > Home Audio > Pro Audio > External sound cards as stand-alone ?
Forum Home Audio : Pro Audio External sound cards as stand-alone ?
Archived from groups: rec.audio.pro (More info?)
Hello,
I plan to buy an external soundcard for my laptop and I am thinking of
the m-audio firewire audiophile.
I have one basic question though; can it be used as stand-alone also
(for instance as external DAC to a CD player) or it has to be
controlled by the laptop
Thanks for any help
Argiris
Reply to Anonymous
<arg_@hotmail.com> wrote in message
news:1106576972.237258.240860@f14g2000cwb.googlegroups.com
> Hello,
AFAIK, almost all external audio interfaces including the one you mentin
must be controlled by some external host. Firewire is interestng, bcause at
some level it is a peer network. In contrast USB is generally thought to be
a host/client network. While its tough to make a peer network out of a
host/client network, the reverse can be doable - even easy.
Therefore, devices on a Firewire network can still conform to the
host/client model. As a rule audio interfaces are clients, not hosts and not
peers.
Also, the basic concept of using an external DAC with a CD player is not the
best idea. Better to get a good modern optical disc player that has very
good converters of its own. Might set you back $50-100! ;-)
Reply to Anonymous
I CAN tell you that they have recently released a new driver (5.10.0.5032)
that fixes several previous issues, and is available for download on their
site; although it will not function standalone. It needs to communicate
with the PC (it's mixer software). I have both this device and a firewire
disk drive daisychained and I am very pleased with the setup. The only
issue is that the Audiophile must be powered on in order to daisychain the
disk drive. The NEW driver is a MUST however.
Reply to Anonymous
Dunno on the M-Audio, but the RME Multiface and Fireface can both do this. They will function not only as an ADC and DAC, but will preserve I/O routing and headphone matrix settings as well. They do need to have continuous external power (AC for the Fireface, DC for the Multiface) in order to preserve the config.
Reply to Anonymous
Thank you all for the info. It seems it can't be done, however I will
propably still get one as it seems very good value for money
all the best
Argiris
Reply to Anonymous
metric halo uln2
has boot state and 9 snapshots which allow it to be used as a stand
alone interface
dale
Reply to Anonymous
Fireface800 does NOT need to have continuous power to preserve
settings... You can save settings (with the driver GUI in your computer)
into it's internal memory and keep these there without any power. Then
you just switch it on as standalone and the settings are there.
Sven
Reply to Anonymous
Cool, thanks for the update. Wish it had DC power input, though...
Reply to Anonymous
There are 1535 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Should I turn my speakers off to avoid damage?
By mubin, 1 day ago:
Do you mean when jack is connected then there is that noise? Then it is the cable. In my...
Best offers
Top experts
