Tom's Hardware > Forum > Audio > Pro Audio > Any Shure Model 55 microphone Experts out there?
Forum Audio : Pro Audio - Any Shure Model 55 microphone Experts out there?
Archived from groups: rec.audio.pro (More info?)
I bought a Shure Model 55 multi-impedance Unidyne microphone on Ebay
recently, intending to use it with my vintage ham radio equipment. The mic
is working, but the frequency response is clearly not what it should be.
There is little or no lower midrange/bass response. I have examined the mic
cartridge and it appears to be undamaged and the voice-coil moves freely.
My preamp does provide the proper impedance matching for the high output
impedance setting of the 55.
A friend of mine bought the same model a year ago and had exactly the same
problem with it. Is this typical of the Model 55, or are we both just
unlucky?
Plus, if anyone has any insights into how the cardioid pattern of this mic's
cartridge is obtained, I'd be very interested in hearing about it.
Visually, I don't see any of the trappings I associate with the usual
phasing approach to achieving a cardioid pattern with a moving-coil dynamic
element.
Any help or info will be much appreciated.
Thanks, Bruce AB7YD
Sponsored Links
> unlucky?
> element.
This may help:
http://www.shure.com/pdf/discontinued/55s.pdf
Reply to Anonymous
In article <23aJd.4311$YD5.3468@newsread3.news.pas.earthlink.net> ab7yd@earthlink.net writes:
That's probably about like it's supposed to be. Someone gave me two of
them a little while ago. After trying them out, I decided to mount
them on a piece of wood, attach it to the wall, and use it as a hat
rack.
I'm really Mike Rivers - (mrivers@d-and-d.com)
However, until the spam goes away or Hell freezes over,
lots of IP addresses are blocked from this system. If
you e-mail me and it bounces, use your secret decoder ring
and reach me here: double-m-eleven-double-zero at yahoo
Reply to Anonymous
Damn, Mike. Don't you know that 55's are supposed to be used only as shoe trees?
Stephen Sank, Owner & Ribbon Mic Restorer
Talking Dog Transducer Company
http://stephensank.com
5517 Carmelita Drive N.E.
Albuquerque, New Mexico [87111]
505-332-0336
Auth. Nakamichi & McIntosh servicer
Payments preferred through Paypal.com
"Mike Rivers" <mrivers@d-and-d.com> wrote in message news:znr1106616218k@trad...
> rack.
Reply to Anonymous
In article <ct5dul$pks$1@reader2.nmix.net> bk11@thuntek.net writes:
> trees?
My feet aren't that big, but my head is that small.
Reply to Anonymous
hey Mike the problem is probably the stock setting on the mic..some have a HML switch on the bottom back part of the grill that allows you to set the impedence at High, Medium, or Low hense HML. if your model is one without this then most likely the out put is gonna be low. unless you get an inline transformer to boost the signal......these mics were not made for a lot of output....... and as for a cartoid pattern, it has a omni- directional pattern, meaning it pics up sound from the front back and sides, hense the grill openings all the way around....each side is a certain distance from the element and had two screens to pass....eac was to pic up sound and the silks or foam was to slow the sounds down just enough to get a full rich sound alost like four voices at once or a early form of reverb. It was a break through for its time...but now they are not very good for sound quality Unless you are looking for that tinny sound compaired to modern mics....go to mutantmics.com and see if you can find something to help you there. this guy deals with upgrading 55's and customizing them fully. He even lights them up. and put new mics like the sm58's and beta in them.
Reply to whoizicc69
There are 620 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
