What sort of adapter problm are you having ?
If your not gaining access to the internet then your adapter may be off and needs to be enabled.
On the laptops keyboard you will see that some keys have a second letter or symbol on them in a different color. This second set of letters and symbols can be activated by the Fn key located near the Windows key , you want to locate the key that has a wireless symbol on it. Some laptops it's on one of the F keys at the top og the keyboard.
Once you locate the wireless symbol press the Fn key and the key with the wireless symbol at the same time and you will activate the wireless adapter.
If it doesn't work then press the Fn key once and then press the key with the wireless symbol next.
