Hello guys! I recently upgraded most of my computer parts and reformatted from windows 7 enterprise 32bit to win7 enterprise 64bit. (all of this happened in a computer shop)
I never had internet problems before the reformat, however it has happened to me before when I had previous
newly reformats on my pc which usually goes away after 2-3 months.
here is the problem, the internet is fine when I start using it and after an hour or two it will disconnect and when I troubleshoot
it, it will just say "DNS server isn't responding" and what I do is turn the modem off and turn it back on and the internet will
come back after 10-20 seconds. so basically my internet is fine and will just go down then to fix it I just have to turn the router
off and on, but it is quite bothering since I work at home and this has been a nuisance.
Additional Info:
my network drivers are up to date.
I used a driver detection software and say that all are updated.
I already installed all win 7 updates.
My modem's name is Zyxel P-660HN-T1A
I have tried openDNS.
any more ways to narrow it down?
Additional Info:
