Tom's Hardware > Forum > CPU & Components > Sound Cards > Audigy Drive with Audigy 2 Sound Card?
Forum CPU & Components : Sound Cards - Audigy Drive with Audigy 2 Sound Card?
I have an Audigy Platinum. It came with the 5 1/4" drive that enables you to move lots of connections to the front of your box. I love that feature. Now, I'd really like to upgrade to the Audigy 2 sound, but I really do NOT want to buy the Audigy 2 Platinum. Will the Audigy drive work with an Audigy 2 sound card? Are they essentially the same?
I want to move to space, so I can overclock processors cooled to absolute zero.
Sponsored Links
Anyone?
Reply to Twitch
I am pretty sure that the answer is no, a audigy 2 must have a audigy 2 drive, they changed the conections
Reply to mattburklund
I the same question a while ago and nobody knew for sure either. Someone needs to try it or at least check out the connectors.
<font color=purple>AMD XP 2200+, A7N8X Deluxe, 512mb PC3200 Corsair XMS DDR, Geforce3 Ti-500, Audigy Platinum, TDK 48x CDRW, Lite-On 16x DVD, XP Pro SP1, and more neon than a ghetto sled </font color=purple>
Reply to KWPLunchbox
There are 1169 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
