Solved
Sandisk pen drive write protected problem
how do i remove write protected problem from my pendrive
2 answers Last reply Best Answer
More about sandisk drive write protected problem
  1. Best answer
    Right click on the Pen Drive in My Computer when inserted and check the properties.
    Under that you will see a read only box. Remove the tick from it and apply.
    Then format the drive and it'll be ready to use.
  2. Best answer selected by sairam_60.
Sandisk Pendrive Windows 7
