Installation problem
Last response: in Windows 7
June 11, 2012 2:07:17 PM
Hello,
I was trying to install blackberry plug in browser but it wont progress saying that an installation is already in progress complete that before continuing with the current installation,similarly i cant download other application updates, i am using windows 7 on my sony vaio laptop. I can figure out what installation is in progress,apparently there is nothing installing,neither have i started any installation?
More about : installation problem
June 11, 2012 2:40:01 PM
Try resetting the WindowsInstaller service in the services list
type services.msc in the start menu search.
Find it in the list
Disable it then Reboot
Go back to services.msc
Set it to Manual
Try your install again
m
l
June 19, 2012 7:39:04 PM
thanks alot! it worked:)
m
l
June 19, 2012 9:08:37 PM
great please mark as solved :-)
m
l
