Noise from Ethernet Connection
Last response: in Home Audio
Anonymous
January 30, 2005 7:17:18 PM
Archived from groups: rec.audio.pro (More info?)
I've been getting a terrible buzzing sound in my monitor speakers for
some time now and I just discovered that unplugging my ethernet
connection from my cable modem eliminates it.
Has anyone else noticed this type of thing and what did you do about it?
Anonymous
January 30, 2005 11:20:38 PM
"Adam Ludwig" <ludwigadam@comcast.net> wrote in message
news:W7ydnVP-S7JB02DcRVn-ug@comcast.com
> it?
Probable cause is probably not electrical noise from the ethernet cabling,
but PCI bus interference effects.
http://www.musicxp.net/tuning_tips.php
Anonymous
January 31, 2005 2:43:54 AM
In article <W7ydnVP-S7JB02DcRVn-ug@comcast.com>,
My strong suspicion is that either your cable modem or your computer (or
both) have ethernet interfaces that are not isolated according to spec.
Or possibly you are using cable that doesn't meet Cat-5 spec and is
radiating trash, though that is less likely.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
Anonymous
January 31, 2005 11:35:28 AM
In article <W7ydnVP-S7JB02DcRVn-ug@comcast.com> ludwigadam@comcast.net writes:
Almost everyone has. Cable TV systems have a lot of ground noise. The
thing to do about it is to keep the cable system away from your audio
system. If you absolutely can't tear yourself away from the Internet
when you're working in your studio you can try using an isolation
transformer between the TV cable and the first box it hits when it
gets to the house.
A cheap way to do this is to connect two 75/300 ohm transformers back
to back and put it in line with the TV cable. You'll need a gender
changer for one of the 75 ohm connectors as well as the two adapters.
I'm really Mike Rivers (mrivers@d-and-d.com)
However, until the spam goes away or Hell freezes over,
lots of IP addresses are blocked from this system. If
you e-mail me and it bounces, use your secret decoder ring
and reach me here: double-m-eleven-double-zero at yahoo
Anonymous
February 10, 2005 7:17:13 PM
> gets to the house.
The noise is caused because you have 2 ground sources in your system,
the groudning in cable TV AND the 3rd prong ground in the devices you
plug into the wall outlet. Like what myou did, if you remove one type of
ground, everything's OK. I had the same problem with my computer
connected to the stereo. To solve it, I removed the ground plug from my
computer and monitor. I could not isolate the cable TV:)
CD
Anonymous
February 11, 2005 1:31:06 AM
On Thu, 10 Feb 2005 16:17:13 -0500, Codifus <codifus@optonline.net>
Don't try this at home kids.
Chris Hornbeck
