Tom's Hardware > Forum > CPU & Components > Other Components > Case Fan Heat Sensor
Forum CPU & Components : Other Components - Case Fan Heat Sensor
Hi all, yay my first post! Anyway, I just bought a Case fan for my PC cause it was running a little hot. This fan comes with a little heat sensor (almost looks like a little filament attached to the fan with a wire), my question is where do I place the sensor? Its not a CPU fan, I'm just using it to cool the box, so should I put it near the chipset somewhere? No-one I know can give me a good answer so any help is appreciated, thanks.
Sponsored Links
As close to the top of the case as it will go.
Heat rises.
<b>(</b>It ain't better if it don't work.<b> )</b>
Reply to Teq
There are 1044 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
