I am using a microphone that requires phantom power from the board. I
also want to use a direct box for a split back to my stage amp. I have
been looking for a direct box with an XLR input, a quarter inch link,
and most importantly, one that will pass phantom power through it from
the console to the microphone. Can anyone help?
<antemoticon@yahoo.com>
** You need a standard, passive *transformer" DI box - such a box
blocks DC on the XLR socket. Then you also need an XLR mic lead Y adaptor
that allows the mic to connect to both the DI and the board.
So, the signal goes from the mic to the board, then also via a parallel
split to the DI and from one of its jacks to the stage amp.
<antemoticon@yahoo.com> wrote ...
> from the board. I also want to use a direct box for a
> split back to my stage amp. I have been looking for a
> direct box with an XLR input, a quarter inch link, and
> through it from the console to the microphone.
> Can anyone help?
Perhaps what you are looking for is a "mic splitter" box.
Many are available that will pass phantom power from
one of the outputs to the input (the microphone).
Mic splitter boxes are typically fitted with a female XLR
connector for the mic input, and two male XLR connectors
for the outputs. If you want to feed the mic to a stage amp
with a 1/4" input, just use cable with female XLR (out of
the mic splitter box) on one end and male 1/4" plug on the
other end (for your stage amp).
Some typical mic splitters found at online vendors...
ART Split-com ($25)
Rolls MS20 Mic Splitter ($39)
ProCo MS3 ($79) (3-way)
In article <1107257722.665478.263380@f14g2000cwb.googlegroups.com>,
You want to run a microphone into a stage amp?
What you actually want is probably a preamplifier and a reamp box. The
levels coming out of the mike are too low to go into an amp, especially
through a backwards DI box.
Do be aware that this is a recipe for feedback problems.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
> ART Split-com ($25)
Hmmm, ART, Rolls, and proCo. I think I'd go with the ProCo.
In article <1107257722.665478.263380@f14g2000cwb.googlegroups.com> antemoticon@yahoo.com writes:
It sounds like you want to split a phantom powered mic to two
destinations - the console (which provides the phantom power) and
another amplifier on stage. Is this correct?
If so, what you really want is a mic splitter. But you have a couple
of problems (or at least, to us, a couple of unknowns). What's your
"stage amp"? A guitar amplifier? What are the characteristics of its
input other than the size of the input jack?
If it's a guitar amplifier or the like, I'd try a simple XLR Y cable
to split the mic, with one branch of the Y going to the console (this
will provide phantom power) and the other branch going to a passive
direct box to sort of match the microphone output to the amplifier
input. That won't cost much and will probably work.
But any time you change the loading on a microphone, you'll change its
sound. It may not matter enough to worry about, but you should be
aware that it will happen.
I'm really Mike Rivers (mrivers@d-and-d.com)
However, until the spam goes away or Hell freezes over,
lots of IP addresses are blocked from this system. If
you e-mail me and it bounces, use your secret decoder ring
and reach me here: double-m-eleven-double-zero at yahoo
Could you give some more details? Most stage amps don't have microphone
inputs, so I'm not clear what you're trying to do. Brand names and model
numbers will help, of microphone, board and amp. Also what this mic will be
used for -- vocals? Instrument(s)?
" ** You need a standard, passive *transformer" DI box - such a box
split to the DI and from one of its jacks to the stage amp. "
** The Parrot's post 8 hours later:
** Is plagiarism is the sincerest form of flattery ??
<midicad2001@yahoo.com>
> Is everything that you post the result of your independent research?
> You never read a book and said "so that's how it works"?
> I realize it's hopeless (sigh)....
** Wonder who's sockputtet this tedious wanker is.
What's your "stage amp"? A foldback system? Tell us just what your
setup is?
Thanks for all the replies so quickly. I have a mic (CAD Equitek E100)
set at the grill of my accordion, and my stage amp is a guitar amp.
Right now I'm running into a small Mackie 12 channel mixer, and from
that I send the main signal from the mixer to the snake, and an aux
send to my stage amp. I have no problems with feedback using this mic
with this setup, it's very one-directional and I have mounted very
close to the grill of my accordion.
I like this setup, for b/c it gives me a signal boost through the
boards mic pre, an xlr send to the snake, and a split to my amp with
the aux. However, it's very clunky and a lot to carry around for one
line. I thought their might be a more portable solution, but now that
I break it down more I guess the DI would not boost the signal at all
like the Mackie's pre's.
> Suggestions?
** That mic has a high output level PLUS a passive DI operating in
reverse as suggested boosts the signal again. You are sure to have plenty of
signal available for any guitar amp.
Stop whining and guessing - go try the solution I posted and the Parrot
echoed.
In article <36ak1nF4v5v0aU1@individual.net> philallison@tpg.com.au writes:
Great minds think alike.
I realize, Phil, that in the perfect world, we should simply all wait
around for you to answer all the questions and then there would be no
need for anyone else on this newsgroup. But I'm an impatient sort, and
if I see a question I can answer before I see your response, I'll
answer it.
Sorry if it takes eight hours to get from here to there. I couldn't
fly there any sooner and deliver my answer to you for you to check out
before posting it.
Phil Allison wrote:
> The Parrot's response is 8.5 hours behind my post - according both to GG
> and my news server.
Who's a clever boy then?
And can you show us at what time his news server picked up the original
question, before which he wouldn't have been able to see it?
CLUE: In the early days, usenet articles could take *days* to propagate.
Now it's a bit faster but the mechanism is the same.
In article <1107344384.990452.3920@o13g2000cwo.googlegroups.com> antemoticon@yahoo.com writes:
That's a fine way to do it.
You could get someone to custom-build a box for you, but it would
still be a box. You'd lose a little bulk and a power cord, but also
lose some flexibility. It wouldn't be worth it. The Mackie 1202 is
pretty small and light, pretty inconsequential compared to most guitar
amps.
<antemoticon@yahoo.com> wrote in message
news:1107344384.990452.3920@o13g2000cwo.googlegroups.com...
> Suggestions?
Run your CAD straight into the snake. Take a Direct or Insert out from the
main mixer to an unused channel of the snake, and run that into your stage
amp.
I
have
from
> Thanks
> -Rick
%% You need a standard, passive *transformer" DI thingey - such a
thingey
blocks DC on the XLR doodad. Then you also need an XLR mic cord Y
adapter thingey doodad that allows the mic to connect to both the DI
and the board.
So, the signal goes to the board from the mic, then also via a
parallel
Turn it up to 11 for maximum effect.
"Particle Salad" <mark@particlesalad.com> wrote in message
newsL8Md.216$zr.149@newssvr23.news.prodigy.net...
> george gleason who files of the handle when anyone mentions the "b" word
in
> a negative light,
> The 'b' word? Beef? Bass? Brunette? Bass Ale? Ben and Jerry's? Beaumont?
> Blues?
> I don't get it...
** The "b" word is Bose.
Particle Salad has got scrambled eggs for brains - if you had not already
noticed.
............. Phil
> Dave Martin
> Java Jive Studio
> Nashville, TN
> www.javajivestudio.com >
> in
>> a negative light,
> thingey
> and the board.
I HATE it when he gets so technical!!
doodadave
> parallel
> --------- meow
