Hi,
I have 3 Windows XP PC's connected by Ethernet cables to a Netgear FS308 5-port switch, and a Virgin Media 30Mb Super Hub is also connected by Ethernet cable to this switch.
I have 4 other PC's and a Thomson TG585 router (telphone line connection) all connected to a different Netgear switch.
I want to connect the 2 Netgear switches and I understand that this is possible with a crossover cable. I need all 7 PC's to see each other on the HOME group network so they can share files.
My problem is that it is very important that when I connect the 2 Netgear switches with the crossover cable that the 3 PC's using the Super Hub for Internet access continue to use the Super Hub only and do not try to connect to the Thomson router for Internet access. The same goes for the other 4 PC's on the other switch (I don't want them to try and connect to the Super Hub, they must contine to use the Thomson router only).
Can anybody please tell me what settings I need to change on the 7 PC's and on the Hub and router to make sure this happens?
Thank you.
Kind regards,
Paul
Thank you.
Kind regards,
Paul
