Wifi connection---mobile connection
sunita88
Hello,
when a wifi connection is available how can i connect my nokia (C5-00, 6303classic )mobile to the internet
pretty much the same procedure as on a wireless laptop.
If your Nokia has built-in wireless capability, go into it's settings >wireless.
Scan for networks. When your router's SSID appears on the list, select that and enter the router's wireless key. From then on, connection should be automatic whenever the phone is within range of the router's wireless signal.
