Archived from groups: alt.cellular.sprintpcs (More info?)
I recently received a free re-conditioned Sanyo 4900 phone after
arranging for month-to-month (i.e., no-contract) service with Liberty
Wireless, a service provider which uses the Sprint PCS network. (I'm
a latecomer to the cell-phone world, and the idea of going with
Liberty was to develop an idea of how much I'll actually end up using
mobile service before locking into a contract with one of the majors.)
Anyway, the 4900 is great, except for the fact that I'm definitely not
getting the 4-or-greater hours of talk time the phone is supposed to
provide. In fact, I'm typically getting just over one hour after a
full charge. I live in a major metro area, and I am using
conservation measures such as minimal LED-on times. And I don't use
the web capabilities (actually I don't even have the option to…but
that's one of those Liberty "surprise, surprise!" stories that I won't
get into here).
Anyway, does this low talk-time suggest that the battery may be
defective? Or that the battery is draining too quickly for some
reason -- either due to a phone or battery defect? In fact the top
part of the phone gets pretty warm after less than ten minutes of
use...does that support the battery-draining too quickly theory?...and
if so, does that reflect a defect in the phone itself or the
battery?...or is the warmth normal for this phone? I notice that,
even though the free accessories sent with the phone do have the Sanyo
name on them, the battery appears to be an aftermarket no-name
instead.
The last thing on earth I want to do is have to mail the phone back to
Liberty, and the fact that some customers call them "Liberty
Worthless" should give you a quick clue as to why. And I don't really
trust them to give me reliable advice in the first place, especially
since there's no bricks-and-mortar store for me to visit -- just
phone/online "customer care". That's why I'm hoping it may just be a
battery issue, since I'd happily shell out for a new battery to avoid
a return.
BTW, does the battery drain quicker when using the speakerphone? How
much quicker? How about SMS messages receipt ? (Liberty sends
unsolicited messages about anytime minutes balance, etc.)
Sorry about the rambling post, but any thoughts on the
barely-over-an-hour talk time would be greatly appreciated, especially
from current or former 4900 owners.
My wife and I had 4900's for a long time and just purchased
4920's to replace them.
One hour on a charge is definitely NOT normal. It is probably
a battery defect. For comparison, a full charge would give us about a
week of relatively idle usage before showing any diminished charge
(according to the charge icon in the upper right). If I used the phone
a lot - that is, more than two hours a day - I'd still get at least
2~3 days before the battery would begin to lose charge. In fact, the
4900 offered near-spectacular charge longevity.
Two things make a big difference. First, is your
software/firmware up to date? Sprint, in any case has been able to
improve battery drainage with firmware updates. Second, are you
roaming? I keep my phones set to "digital only" when I know there'll
be no need to roam. The process of checking for digital and analogue
signals itself is a battery drain. A 3G phone on a digital system uses
very little power. OTOH, when I was traveling in the west Texas desert
and there was no digital signal whatsoever, a full charge lasted us
exactly one day.
As for the phone becoming warm in under ten minutes, that
sounds completely normal.
David G. Imber <imber@maniform.com> wrote in message news:<n2bkd0tqmlbu38498vf0ivfmilgakoqo2b@4ax.com>...
> exactly one day.
Thanks for the ideas. I'll try a new battery first; maybe the one
they sent me is actually used. Rememeber, this is a (purportedly)
manufacturer-reconditioned phone. If that doesn't work, I'll look
into your other ideas, although I can tell you now that roaming isn't
an issue -- I've always been well within the Sprint digital network
area
On 24 Jun 2004 13:53:47 -0700, haroldse@yahoo.com (Harold) wrote:
>David: I recently did a more rigorous check, and I got more like 2
>hours talk time, but that still sounds way too short.
Yes, I agree. On a recent business trip I used the phone for
about 2 hours a day for three days before the battery icon showed any
loss. The battery icon isn't a precision indicator, but it gives you a
roughly analogous idea.
There may also be a device within the unit's circuitry that
governs power usage, and that may be defective.
In article <40ab9e53.0406241253.5c09ca39
@posting.google.com>, Haroldharoldse@yahoo.com says...
> Not roaming at all.
> HS
What about searching for service? If there's no signal,
the phone will actively seek one out, and that's almost as
battery intensive as being in a call.
RØß
O/Siris
I work for SprintPCS
I *don't* speak for them.
O/Siris <0sîrîs@sprîntpcs.côm> wrote in message news:<MPG.1b46d27f33b4b9b2989a2d@netnews.comcast.net>...
> > Not roaming at all.
> > HS
> > Not roaming at all.
> > HS
Except for a few uses during a trip I took a month ago, the phone has
always found a signal within seconds.
David G. Imber <imber@maniform.com> wrote in message news:<np7ud01fgt9uku85rn5gnpqsv9d0hl2si5@4ax.com>...
> But I'm still convinced that you have a problem with this
> unit's power usage.
> Best of luck w/that.
> DGI
Thanks. Unfortunately, it turns out that you and the others who
suggested that this is likely a problem with the phone itself were
apparently right. I tried a brand new standard battery in the 4900
and it only bumped up the talk time a little bit, still under
high-conservation conditions.
Rather than deal with the well-documented pitfalls of trying to
arrange a successful repair or exchange via mail with Liberty
Wireless, I'm going to spring for an OEM extended battery (getting a
new one for $25 from a reputable seller on eBay), and hope that brings
my talk-time to what I should be getting with a *standard*
battery...which is sufficient for my needs. Hopefully it will be as
simple as that with no further complications, though I'm only mildly
optimistic.
>optimistic.
Sorry you're having so much trouble. I just sold two 4900's
that had been used lightly, but weren't by any means brand new. They
both had superb power retention nonetheless.
