Tom's Hardware > Forum > CPU & Components > Sound Cards > Need a simple solution
Forum CPU & Components : Sound Cards - Need a simple solution
I'm playing bf1942, while I enjoy the game immensely I sometimes miss out on the occasional explosion because I'm playing with Sound max integrated sound. I've looked around and don't honestly know if I should drop the bucks for a 24 bit sound card. How much better is a regular 16 bit soundblaster than the integrated I'm using? Is a 24 bit even worth it for my needs. Any suggestions will be considered and appreciated.
Thanks
Sponsored Links
the difference between 16-bit and 24-bit is like the difference between a Duron and an Athlon. 16-bit is good if you have dick for a budget, otherwise go for the 24-bit. You will be rocked by how much clearer and realistic the game will sound. It's like night and day.
XP 2500+ Barton
A7N8X Dlx
2x512MB Corsair PC3200
MSI GF3 Ti500 w/64MB DDR
16x DVD-ROM
2x80GB 7200RPM Maxtor
Onboard audio
My computer is bigger than your computer....
Reply to umheint0
There are 1189 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
