Ok, I've got an old beater machine that I use, its a Celeron 433, motherboard of unknown Origin, running windows 98. None of which applies to my problem.
Last night, while playing games, my monitor would just go black, then have random red lines scambling across it. Turning it on and off would clearn things up, but generally the machine would stop working after 10-15 min.
This morning, while waiting on a Tow Truck for my dead Car (also a Battery Problem).. I thought I'd take the cover off and power it up to see if the Fan on the CPU was working correctly. I was thinking maybe the fan had died and it was overheating or something along those lines.
About.. 30? seconds after powering up, there's a Loud Bang, sparks, sizzling noises, flames and smoke shooting out of the vents on the powersupply.
It was very dramatic.
Needless to say, In Vain hope that I've not fried my machine entirely, I picked up a new Power Supply from CompUSA, decided to upgrade the original 250W supply with a new 300W P4 ATX from NSpire.
I've never replaced a power suppy before, I thought itd be a simple process, unplug the old PS from the Motherboard and the various parts, plug the new connectors in after putting in the new supply.
I find however, I've got an extra 4pin square connector that does Not go to anything on my motherboard. And, after trying to start it anyway I've got Nothing. No lights, no fans, nada.
Left the wattage switch at 115? whatever the shipping setting was, and tried both positions for the switch on the back. Used a New cord, and plugged into different jacks on my extention.
So, the question is, do I go back to CompUSA and get a regualr 250W supply, or am I just doing something wrong?
Mike
Mike
