Tom's Hardware > Forum > Storage > CD-ROM/DVD-ROM > Pioneer DVD problem
Pioneer DVD problem
Forum Storage : CD-ROM/DVD-ROM - Pioneer DVD problem
Hello everyone,
I have pioneer DVD rom slot in drive (DVD-106S) but I can't get any subtitle text from DVD film. I can get the subtitle when I tried the same DVD film on DVD player in Hi-Fi system. I'm using Cyberlink powerDVD and Microsoft Media Player, both of them can't show the subtitle. My OS is Windows XP.
What's wrong with this? How can I fix this problem?
Thanks
Sponsored Links
Subtitles usually appear below the video portion of DVD movies. Did you play the DVD at full screen (the subtitle might be outside your display area)?
Reply to elzt
Yes, I played it full screen. The subtitle menu is selectable but nothing happened when I select the subtitle language that I want.
Reply to cloud_kjo
- 0 +
Have you tried to resize the video screen to a smaller size to see if it works? Also what video card are you using? Video cards with insufficient memory might also cause the problem.
Reply to elzt
The problem has been solved!! I think my VGA card is the culprit. When I change my radeon 8500 to radeon 9700, amazingly the problem just dissapeared.
Thank you anyway
Reply to cloud_kjo
There are 1141 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
