Tom's Hardware > Forum > Audio > Pro Audio > Sound-reducing glass advice please.
Forum Audio : Pro Audio - Sound-reducing glass advice please.
Archived from groups: rec.audio.pro (More info?)
I have a few interior windows of the old, double-hung type. They
transmit a lot of sound from the outside into a home studio and living
room. In short, the dog next door and slamming car doors are intrusive.
Instead of installing expensive double-glazed storm windows, I thought
I'd try to attach some glass over the window from the inside. I never
open these windows, so no problem there. Perhaps just a piece of glass I
could lay over the window and affix with mirror-type fittings.
I'd appreciate any information about the best glass for reducing sound,
or any other material that might even do a better job. Websites articles
or any recommendations welcome.
(to the list, please)
RG
Sponsored Links
"Richard Gecko" <geck@nomac.com> wrote in message
news:geck-573AAB.18230714022005@newssvr11-ext.news.prodigy.com...
> RG
You will have little success with the approach you suggest.
Multiple-layered pane windows reduce sound transmission by trapping air
between the panes. That means that one needs an air-tight seal, when
glazing in the second or additional panes. In addition, old double hung
sash windows are typically very leaky around the frame. So, even if you do
glaze the new glass in a fashion to achieve an air-tight seal, a significant
amount of sound will leak around the edges of the frame. With all of that
said, you may be able to achieve ... some ... noise transmission reduction
if you install an additional glass pane. And, a standard thickness pane as
large as a double hung window will be pretty useless. You'll have to go
thicker... 1/4 inch at least. You must approach it as you would install a
weather proof window. That means well caulked trim strips all around on
both sides of the glass, closed-cell foam weather stripping on each side of
the glass all around, and solid rubber spacers for the glass to rest on to
keep the glass from touching the frame. Unfortunately, you will not know
ahead of time how successful this project will be until you do it.
I had a similar yet easier problem to solve with my basement studio. There
are two metal framed casement windows in the poured concrete foundation very
close to my recording position. I removed the casement windows entirely. I
added a wood frame within the metal frame caulking those framing pieces
thoroughly. Within that new frame I installed a double pane system
consisting of one piece of 1/4 inch glass and another pane of 3/8 inch
Lexan. Both pieces are floated on solid rubber spacers and encased around
the edges in closed cell foam weather stripping. As soon as I did this, my
neighbors dogs, aircraft, and the other usual suburban noise went away. As
long as no one mows my back yard, while I am recording, I'm good to go.
Since I mow my own yard, even that's not a problem.
Another thought, unfortunately not a very encouraging one... if your house
does not have really substantial construction with fairly dense insulation
within the exterior walls, a lot of the exterior noise you hear will come
right through the walls negating the energy and expense you put into the
windows. Hate to be so negative.
Good luck. Let us know how it turns out.
Steve King
Reply to Anonymous
>> RG
What if he were to install 1/4 inch Lexan over the frames, sealed airtight,
on a gasket? Then he gets some mass, plus some bonus security.
Rob R.
Reply to Anonymous
"Rob Reedijk" <reedijk@hera.med.utoronto.ca> wrote in message
news:cutm03$164$2@news1.chem.utoronto.ca...
SNIP
> airtight,
> Rob R.
On the inside? Around the whole frame gasketed to the wall? I doubt it.
The glass or plastic pane has to be mechanically insulated from everything
else. That means a new frame gasketed to the wall with the little rubber
spacers to provide support and mechanical isolation. Might help, but not
knowing the wall construction impossible to know whether the result would be
worth the expense and the amazement of the wife, when she sees the
innovative new architectural features in her living room.
Steve King
Reply to Anonymous
"Steve King" <steve@45steveking57.net> wrote in message
news:D9udnc7sobwNC4_fRVn-qg@comcast.com...
intrusive.
> SNIP
> > airtight,
> > Rob R.
be
> Steve King
The only glass with "sound reducing" qualities of any significance is
laminated glass. Not too expensive, but correct installation is key to the
result. Consult an acoustician.
If it 'rings' when you tap it; it's an amplifier @ that frequency.
jepp
Reply to Anonymous
> RG
I have no neighbors close enough to worry about, but I currently have a
problem with the singing of birds - it's truly amazing how loud they can
be. I plan to install fairly heavy wooden shutters which I will close
when necessary. But then it's a large barn-like space with plenty of
room. Something similar in your house might be too intrusive. But it's
worth considering the idea that you needn't use glass - unless you must
look outside during recording (I can't think why that would be).
-Naren
Reply to Anonymous
Birds are mostly high frequency stuff, which helps. Two panes of half-inch
glass with an airspace between them ought to give you more than enough mass
to deal with that stuff.
The alternative is to get a lot of really big cats in the yard.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
Reply to Anonymous
"Scott Dorsey" <kludge@panix.com> wrote in message
news:cv4rsk$gjp$1@panix2.panix.com...
> half-inch
> mass
> --scott
And the cats are way cheaper.
Steve King
Reply to Anonymous
Yes but then the cats make noise, and then you need to get really big dogs.
And then the dogs make noise and you need to get...
Rob R.
Reply to Anonymous
So the effective alternative is to decorate your yard with those big
plastic owls.
ha
Reply to Anonymous
"hank alrich" <walkinay@thegrid.net> wrote in message
news:1gs6mxe.kdi7acxn03j0N%walkinay@thegrid.net...
>> dogs.
> plastic owls.
I had no idea acoustic engineering was so complicated.
Steve King
Reply to Anonymous
There are 838 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
Related Content
