at the bottom of my lap top is my wireless card that two wires connect to but my lap top didnt have them so i had to go out and buy them but dont know how to connect wires to my lap top
If your wireless adapter is broken it would be best to simply replace the entire adapter, unless you have reasonable electronics knowledge. It's not as easy as just buying two wires and connecting them to the laptop, there will probably be some saldering involved.
A second option would be a usb adapter...
