K kmegan824 Honorable Jun 17, 2012 1 0 10,510 Jun 18, 2012 #1 Hello, my desktop internet works but my laptop wont it finds the network but says "limited access"
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,614 1,778 159,590 Jun 18, 2012 #2 Do you use a software firewall? Upvote 0 Downvote
G Guest Guest Jun 18, 2012 #3 Go to Device Manager and look to see if your network device is yellow. If it is, you should try and reinstall the driver for it. Upvote 0 Downvote
