hope this is right forum group...
trying to understand diff in read speed on my setup and other similar setups but with diff mobo/chipset..
my specs are: asus a7v8x(kt400), xp2000, 1024mb pc2700 crucial (cl 2.5)not oc'd
when i run aida32 benchmark to look at my read speed i get around 1850mb/s. i understand because of my 133 MHz FSB that my scores will be close to PC2100 DDR scores as indicated by the 1850 reading but i'm trying to understand what causes higher read speed benchmarks with my abit kx7 kt333 mobo using same xp2000 and pc2700 cl2.5 (generic brand) ram (with this setup i consistently get 200mb/s higher read speed... i'm not concerned about this small diff... i would like to learn if this is due to the diff of the kt333 vs the kt400 or is it related to the diff mobo or some other variable...
i've tried other brand of pc2700 ram on my a7v8x setup and it makes no diff in readings (still around 1850)
also... since my fsb limits my to pc2100 readings... what's the advantage of running pc2700 on my asus board?
thanks for any help on understanding this....
mega
Megaton
mega
Megaton
