Tom's Hardware > Forum > Mobility Networks > Sprint PCS > Charging problem with Samsung SPH-A660 / VI660...
Forum Mobility Networks : Sprint PCS - Charging problem with Samsung SPH-A660 / VI660...
Archived from groups: alt.cellular.telephones,alt.cellular.sprintpcs (More info?)
Up until recently, my Samsung SPH-A660 / VI660 had been working like a
charm. Recently, I noticed that the battery life isn't what it used
to be. For 6 months, the battery seemed normal, but now it seems like
it drains in under 30 minutes. Moreover, when I attempt to charge the
battery after plugging in the phone at times even after the green
light comes on (indicating that the battery is fully charged) the
battery doesn't seem to get charged after I remove the AC adapter -
the bars indicating charge drop down almost immediately. To make
things even more complicated, this behaviour happens also with a brand
new battery - at times it charges while at other times it doesn't.
When it does charge, all is well. What could the problem be?
Thanks in advance.
Drew
Sponsored Links
"Drew" <google_account@yahoo.com> wrote in message
news:cb185bfa.0410130621.2027148e@posting.google.com...
> Thanks in advance.
> Drew
Drew, are you using the battery charger that came with the phone, or
something you bought at Best Buy or some other place? If you are a different
charger, then the problem lies with the charger.
If you are using the charger that came with the phone, then it sounds like
you need to visit your local SPCS store. Take both the phone and charger and
ask them to check it out. It may turn out you've got a bad charger, or a bad
battery, which can be replaced at no charge under your one year warranty.
Bob
Reply to Anonymous
Ha, ha! Good one, Bob! Replacing a bad charger for no charge!
I'll take my puns wherever I can find them, even unintentional ones here
in a.c.s.
> Bob
Frank Harris in San Francisco with an A620
Reply to Anonymous
"Frank Harris" <frankbhX@XcompuserveX.com> wrote in message
news:ckkrh8$sad$1@ngspool-d02.news.aol.com...
> in a.c.s.
bad
warranty.
> > Bob
Thanks Frank. I see someone read the humor in that one ... :).
Bob
Reply to Anonymous
There are 739 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
