Problem with my Toshiba L455-S5975
Hello,
hi,
I have a Toshiba Satellite L455-S5975 Laptop Computer that is not functioning properly. When I try to turn it on, it only gets as far as a black screen with a flashing cursor in the upper left hand corner. I have tried to recover it but still I only get to the black screen with the blinking cursor in the upper left hand corner of the screen. What is the problem and how can I correct it
1 answer Last reply
More about problem toshiba l455 s5975
  1. if the recovery failed try to do a fresh install of windows. if that fails then you have some defective equipment in your computer.
Cursor Toshiba Windows 7
