Startup problem
I have a Toshiba Satellite L455-S5975 Laptop Computer that is not functioning properly. When I try to turn it on, it only gets as far as a black screen with a flashing cursor in the upper left hand corner. I have tried to recover it but still I only get to the black screen with the blinking cursor in the upper left hand corner of the screen. What is the problem and how can I correct it ? It is Windows 7 Home Premium 32 Bit.
2 answers Last reply
More about startup problem
  1. if the recovery failed try to do a fresh install of windows. if that fails then you have some defective equipment in your computer.
  2. 1) Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on your notebook.
    2) When the machine Starts beeping; release the 0 key.
    3) When prompted by the warning screen; select Yes to continue with the system recovery.
    4) Select Recovery of Factory Default Software; click Next.
    5) Select Recover to out-of-box state. Click Next again.
    7) Click Next to Start recovery.
    As nhasian says, if that fails it's a hardware prob. (Try new HDD?)
Cursor Windows 7
