Problem with caldera dr-dos
hi i have ubuntu and windows 7 on the same pc, but i need to repair install windows 7 but i need bios update but i dont have the battery my pc is dell d630, so i create with neroa boot cd wich contains the bios update executable, then i restart windows and it boots from caldera dr-dos in A:> but i can't switch from a: to z: where is the flash image for the bios, need help?
1 answer Last reply
More about problem caldera
  1. you put the bios update executable and firmware somewhere on the cd when you made it. you dont remember where you put it? I suppose you could search for it with
    dir *.exe /s
Drivers BIOS Windows 7
