Tom's Hardware > Forum > Audio > Pro Audio > HELP w/ Multi-track recording on Logic using ADAT
Forum Audio : Pro Audio - HELP w/ Multi-track recording on Logic using ADAT
Archived from groups: rec.audio.pro (More info?)
Hi, all, total NOOB here. I'm trying to figure out how to record 8
channels of 48k audio simultaneously from DA-88 tapes.
I've got a Tascam DA-98 deck hooked up to an Alesis ADAT A14.
The Alesis is plugged into RME Hammerfall Digi 9652 soundcard on ADAT
1&2. On the back of the Alesis, it says ADAT 1 carries Ch 1-4, and ADAT
2 carries Ch 5-8, although I thought that an ADAT line could carry 8
tracks (or more?).
In the Hammerfall settings app, it shows both ADAT 1 & 2 with sync.
On Logic, I can only get four channels of audio to record, using either
ADAT 1, 2, or both plugged in. I desperately need help on this, anyone
have any info to offer?
Thanks in advance, - J
Sponsored Links
ADAT
> tracks (or more?).
either
anyone
What the hell is an A14?
Mike http://www.mmeproductions.com
Reply to Anonymous
It's an AES/EBU Converter box:
http://www.dv247.com/invt/24875
ADAT
> ADAT
8
> > tracks (or more?).
> either
> anyone
Reply to Anonymous
> transmogrifa wrote:
8
> ADAT
and
> > ADAT
carry
> 8
> > > tracks (or more?).
sync.
> > either
> > anyone
Well Smux caries four channels per alesis fiber optic cable at 96khz.
That might be what that is refering to but I am not that familiar with
the AES/EBU spec. I believe AES/EBU is capable of 96k itself. It may
very well be carrying all 8 at 48 khz. But I don't think AES carries
any clock signal where as spdif does so I think you have to have word
clock connections between an AES/EBU device and something else.
Why don't you open the software and make a test transmission and see
how man channels you are getting over one adat in.
Reply to Anonymous
There are 1321 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
