Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Sound Cards > sound card vs onboard sound
Forum CPU & Components : Sound Cards sound card vs onboard sound
I want to clerify something that I read in this forum. I am looking at buying a new system. It comes with the ASUS A7N8X Deluxe mobo. It has nforce2 sound on the board. Will I notice any difference in performance using onboard sound vs a sound card? I run MS FS2002. I will need all of the performance that I can get.
Thanks
Ken
Reply to klf
It depends on what soundcard you're talking about. If you mean an SBLive! 5.1, the onboard will blow away the soundcard. If you mean an RME Digi96, the onboard will be blown out of the water by the quality. If you mean an M-Audio Revolution or an Audigy2, it'll be the roughly the same, both quality and performance-wise.
XP 2500+ Barton @ 2241Mhz
A7N8X Dlx
2x512MB Corsair PC3200
MSI GF3Ti 500
16x DVD-ROM
2x80GB 7200RPM Maxtor
Onboard audio
Reply to umheint0
- 0 +
Thats a handy comparison. I dont suppose you know how the older A7v8X compares do you? (I think it uses Realteks AC97 codec instead of Nforce2)
I have recently upgraded and my old machine had a SB AWE32. How does the on-board sound of the A7V8X compare with that and other sound cards currently on the market?
Reply to gebbly
The A7V8X is roughly similar, if not better, than the AWE32. Compared to mainstream soundcards out there, both pale in comparison. They just don't have the power of the latest soundcards, like the Audigy2 series, the Revolution 7.1, any of the Guillemots, or RMEs, or even the Soundstorm.
I like the soundstorm a lot. At times, it seems a little tinny at the high frequencies, but the low end makes up for it with crisp, clear response. I think it's worth the few extra dollars, not to mention the second LAN connector and two more USB ports. It's a good system, the A7N8X Deluxe.
A7N8X Dlx
MSI GF3Ti 500
16x DVD-ROM
Onboard audio
Reply to umheint0
- 0 +
Thanks for the response. Your system is similar to the system that I am looking at buying. But my main question is this: does the onboard sound on the ASUS card decrease the overall performance of the system, or does the sound have it's own processor?
Thanks,
Ken
Reply to klf
You will notice absolutely no difference in performance.
A7N8X Dlx
MSI GF3Ti 500
16x DVD-ROM
Onboard audio
Reply to umheint0
- 0 +
SoundStorm does have its own APU (Audio Processing Unit), it's unlike any on board audio controller. SoundStorm is more like combining an external sound card along with the mobo which features true Dolby Digital 5.1 encoding, if you think a sound card would decrease overall performance, then SoundStorm would too.
You never know how stupid you are until you have done something stupid enough for you to realize it.
<A HREF="http://www.anandtech.com/mysystemrig.html?id=22996" target="_new">My System Rig</A>
Reply to TKH
- 0 +
Check the latest sound card review on THG. You'll know that I'm not talking big here, SoundStorm DO NOT decrease onverall performance much, actually it beats Audigy2, Fortissimo III, Realtek and C-Media on system resource usage.
Reply to TKH
- 0 +
If the onboard Asus is an ac 97, you will lose 13/15% in performance.
Reply to pjf
There are 1485 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Help Understaing Hardware Montior readings
By DJDeCiBeL, 4 hours ago:
 I agree with that assessment, and with the temps in that range, it's nothing to...
Best offers
Top experts
