Tom's Hardware > Forum > Audio > Pro Audio > help with choosing sample rate, bit rate, max bandwidth
Forum Audio : Pro Audio - help with choosing sample rate, bit rate, max bandwidth
Archived from groups: rec.audio.pro (More info?)
Hi,
For some lower quality endoding of files to mp3's, I noticed
that I can choose different sample rates for the destination
file-- ie: 32000, 22000, 16000.
I encoded one file at 40kbps/22000 and then again
at 40kbps/32000.
They were both the same size after encoding.
However, the 'maximum bandwidth for the files were:
32000 was 4235Hz
22000 was 6032Hz
I figured the higher bitrate would have the higher bandwidth,
but it does not--the program Cool Edit Pro, adjusted it
automatically.
What I am wondering is, how much does the sample rate effect
the quality of mp3 files? And is there a formula to calculate
proper cutoff?
And why did the bandwidth go down for a higher sample rate?
The reason I'm trying to figure this out is because I am seeking a
happy medium between smallest size possible with acceptable quality.
Thanks,
Mb
Sponsored Links
is anybody going to answer this?
Reply to SilentBob420BMFJ
half of the sampling rate is the maximum frequency. CD = 44.1KHz = Freq response 22.0KHz. DVD = 48KHZ sampling rate = 24 KHz maximum Frequency response
Reply to rallycars
There are 535 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
