News
CES 2007: Palm launches Treo 750 smartphone
Palm chose the frenzy of the Consumer Electronics Show to introduce its latest Treo smartphone: The Treo 750 is the new flagship of the family and - other than previously expected - does not integrate Wi-Fi connectivity, but comes can be upgraded free of charge to support UMTS/HSDPA. Read more
GPS can help give early warning of tsunamis
Using GPS (global positioning system) data to measure how points on land move following an undersea earthquake could help geologists decide if the tremor will cause an ocean-wide tsunami. Read more
SecureMac Issues Trojan Warning
SecureMac last week posted a warning regarding a Trojan horse, AppleScript.THT, which affects Mac OS X 10.4 and 10.5. Read more
SD cards in tight supply due to Toshiba production problems
The supply of Secure Digital (SD) flash-memory cards is currently falling short of growing demand as Toshiba may be experiencing some production problems for its SD modules, according to sources with DRAM-module makers in Taiwan. Read more
Latest Reviews & Articles
GeForce 3D Vision: Gaming Goes Stereo
Do you remember the stereo glasses that were around about 10 years ago? Now that 120 Hz LCDs are starting to pop up, Nvidia is teaching an old dog some new tricks with its GeForce 3D Vision shades. Read more
AMD Phenom II X4: 45nm Benchmarked
Can AMD finally recapture its former market lead with the Phenom II? We tested their new 45-nm CPU, which is compatible with AM2 motherboards. How do things look from performance, energy consumption and overclocking perspectives? Read more
Best Graphics Cards For The Money: Jan. '09
Detailed graphics card specifications and reviews are great—that is, if you have the time to do the research. But at the end of the day, what a gamer needs is the best graphics card within a certain budget, and that’s what we’re going to show you. Read more
Scorpio Blue: Big Notebook HDDs Go Mainstream
While two other 500 GB mobile hard drives have been available for a while, WD is the first to release this capacity in a model using the standard 9.5 mm height with two platters. Read more
All the Reviews & Articles
  Tom's Hardware Forums » Mobility Networks » Sprint PCS » Treo 650 problems - A Warning to upgraders
Word :   Username :
Bottom
Author
 Thread : Treo 650 problems - A Warning to upgraders
More Information
Archived from groups: alt.cellular.sprintpcs (More info?)
Perhaps someone else can benefit from my wasted time...
I have a new Treo 650 as a replacement for a Palm VIIx and a Samsung
SCH8500. After installing the Palm Desktop software from the CD and
syncing the Treo, per the installation instructions, the phone worked
just fine, and I was quite happy.
Later, however, I decided to try some of the apps on the phone. There
were a bunch which appeared to be Internet related, such as ABC News,
Amazon, Barnes & Noble, etc. All produced an error code 3402.
I also tried the "Expense" app. This was the most puzzling. When I
tapped the "New" button, the Treo reset itself. I called Sprint
customer support, and finally got through to Tech support after
several minutes of unnecessary explanation. The Tech support rep had
me try a bunch of things including a hard reset after which I had to
re-synch to get my contact list back. He then told me to take it to a
Sprint store. At the Sprint store on Thursday, I wasted about an hour
and was told to come back on Monday because they didn't have any
replacement Treo 650s available.
Yesterday, while researching the 3402 error, I discovered that it
occurs when trying to run an app written for a prior generation of
Palm processor. Those apps won't run on the Treo 650! How about the
Expense app? Yup, same story, just a different failure mode.
The Palm Desktop had blithely installed over the top of the old
version and had installed old, incompatible apps on my new Treo 650.
BE CAREFUL if you are upgrading from an older Palm OS device to the
Treo 650. Don't try to install the older apps!
Tom Brown
thombrown at san dot rr dot com
Member SCOUG, V.O.I.C.E. & SDAA
running eComStation GA + FP 3
Related Product
More Information
There are directions on PalmOne's website to rename your backup folder
before upgrading to prevent just this from ocurring. You can then add things
back one at a time and test for compatability.
"Tom Brown" <thombrown@san.nospam.rr.com> wrote in message
news:1dg3dd6yrPYX-pn2-oI5Rd5tL3Tjc@localhost...
> Tom Brown
More Information
Yeah, but who would have thought to look for such a thing? The
installation program for the new version of the Palm desktop shaould
have had some mechanism to at LEAST warn the user! I know nothing
about the headers or other information contained in Palm software, but
there should be SOMETHING that can be checked to prevent loading of
invalid programs to a Palm device. There should also be some check ar
runtime and an INTELLIGENT mesage displayed in case of an invalid
program. (IMHO) :-)
[snip]
Tom Brown
More Information
And furthermore, most legacy apps *DO* work on the Treo. I use several.
>>Tom Brown
More Information
My 650 resets as well (without error codes) when I play MP3 files within
installed real player
Reset is much faster that I have seen with previous palms and palm phones, I
did not go to the store yet since I know I will spend at least an 1.5 hrs to
find out .......................... nothing
Phone is too new and they do not have much experience yet
> Tom Brown
Google Ads
